Hi All,
Just wondering if anyone would be able to tell me how getting rid of the below bank data import failed message.
Thank you
Hi All,
Thank you
If you are uploading , that’s a an issue with the date format in the excel file.
If you are importing then that would require a support case.
It was an import.
Thank you for the prompt reply
